| Dim Sep 02, 2007 5:16 pm |
Sujet du message: Projet: Formula 88 noir V6 manuel au Saguenay |
Salut
C'est un projet. Elle a été négligé. Entre autres la peinture est brulée par le soleil et le berceau a besoin d soudure (rouillé)
VIN: 1G2PE1197JP205508
Region: 1-North America
Country: G-United States
Manufacturer: 2-General Motors
Make: P-Fiero (P Body)
Restraints: A-manual belts, no airbags
Carline: E-Formula
Body type: 11-coupe 2-door notchback special
Engine: 9-2.8L HO V6 (L44)
Check digit: 7
Model year: J-1988
Plant: P-Pontiac, MI
Manufacturing plant: 2
Plant production sequence number: 5508 /26402
RPO codes:
829: gray cloth interior
19P: Med Gray Metallic, L (lower accent)
41U: Black, U (upper of two tone)
6RD: Metrix cloth, Med. Beechwood
7RD: Red, U (upper of two tone)
82B: Ripple cloth, Medium Gray
82I: Interior Trim, Medium Dark Gray
8UC: Interior Trim, Medium Dark Gray
9UC: Interior Trim, Medium Dark Gray
A01: Window, deep tinted all, Soft Ray
A31: Window, electric control
A90: Deck lid release, remote control, electric
AAA: A coating on the glass
AD3: Window, hinged roof (Sunroof)
AR9: Seat, front bucket, driver, passenger, manual reclining
BC8: Front door map pocket RH and LH (available only w/A31)
C41: Heater, with fan and defroster (84-87)
C49: Defogger, rear window, electric
CD4: Wiper system, pulse
D34: Mirror, visor vanity
D7V: Mirror, inside, RH visor vanity, illuminated
D80: Extension, rear end panel (spoiler-rear deck lid)
DG7: Mirror, RH and LH remote control, electric
E5Z: Mirror, RH and LH remote control, electric
E9Y: Mirror, RH and LH remote control, electric
E9Z: Mirror, RH and LH remote control, electric
FX8: Transaxle, final drive, 3.61 ratio
K05: Block Heater
K34: Cruise control, electric
K99: Generator, 85 ampere
L44: Engine, 2.8L V6 (Hi Output)
MG2: Transmission, manual, 5-speed (Muncie) 3.61 ratio
MM5: Transmission, manual, 5-speed, provisions (85-88 )
N33: Steering column, tilt type
N36: Steering wheel, rally 4-spoke (86-87)
NA5: Emission system, federal requirements
PH0: Lock kit, aluminum wheel
TB4: (front) (86-88 )
TON: (front) (86-88 )
TR9: Lamp group, courtesy consists of;
U25: Rear compartment lamp
U29: Instrument panel, courtesy
U66: Speaker system, 4, dual front dash mounted, dual extended range, package shelf/quarter
UA1: Heavy duty battery
UM6: ETR AM/FM stereo w/clock, cass, auto rev cass,seek & scan (85-88 )
V73: Luggage carrier, deck lid (84-86)
VK3: License plate, front mounting package
W66: Formula option (88 )
WS6: Performance package, special
WV9: Package, value leader, (88 ) (2PM37 + WV9 = WPE37)
X05: Package, value leader, (88 ) (2PM37 + WV9 = WPE37)
XEM: Package, value leader, (88 ) (2PM37 + WV9 = WPE37)
YLM: P215/60 R15 BSW STL (REAR) W/P205/60 R15 BSW
Z31: Build-up, custom door and quarter
Z49: Export, Canadian modification, mandatory base equipment
| Dim Sep 02, 2007 8:09 pm |
fierodave Pegase d'Or
Inscrit le: 29 Jan 2007 Messages: 750 Localisation: Montreal
Salut bienvenue sur fierotalk gene toi pas pour poser des questions ici on a des specialistes (contrairement a dautre site ) moi aussi je possede une formula cest un modele rare prend en soin.
a tu des photos de ton projets ca serais cool de voir ca
 _________________ White Pontiac Fiero Formula 1988
---------- WS6 Package -------------
http://fierodave.monchar.com/ |
| Dim Sep 02, 2007 9:23 pm |
beinvenue sur fireotalk
| Lun Sep 03, 2007 9:28 am |
Sujet du message: Re: Projet: Formula 88 noir V6 manuel au Saguenay |
superdave Pegase de Plastique
Inscrit le: 13 Jan 2007 Messages: 146 Localisation: Rive-Sud
| Lun Sep 03, 2007 10:15 am |
warko Pegase de Bronze
Inscrit le: 29 Jan 2007 Messages: 363 Localisation: Sorel-Tracy
bienvenue dans le club falcon_can
beau projet , |
| Mar Mai 20, 2008 7:22 pm |
| superdave a écrit: | | falcon_ca a écrit: |
K03: Transaxle, final drive, 3.65 ratio
C'est quoi la joke, la voiture a deux transmission??? |
Sait-tu que je viens tout juste de voir ton commentaire et tu as raison,
c'est K05 - Block heater et non K03.
Corrigé !
merci |
