| Dim Sep 02, 2007 5:16 pm |  Sujet du message: Projet: Formula 88 noir V6 manuel au Saguenay |
| falcon_ca Pegase de Diamant
| Salut
 C'est un projet. Elle a été négligé. Entre autres la peinture est brulée par le soleil et le berceau a besoin d soudure (rouillé)
 VIN: 1G2PE1197JP205508
 Region: 1-North America
 Country: G-United States
 Manufacturer: 2-General Motors
 Make: P-Fiero (P Body)
 Restraints: A-manual belts, no airbags
 Carline: E-Formula
 Body type: 11-coupe 2-door notchback special
 Engine: 9-2.8L HO V6 (L44)
 Check digit: 7
 Model year: J-1988
 Plant: P-Pontiac, MI
 Manufacturing plant: 2
 Plant production sequence number: 5508 /26402
 RPO codes:
 829: gray cloth interior
 19P: Med Gray Metallic, L (lower accent)
 41U: Black, U (upper of two tone)
 6RD: Metrix cloth, Med. Beechwood
 7RD: Red, U (upper of two tone)
 82B: Ripple cloth, Medium Gray
 82I: Interior Trim, Medium Dark Gray
 8UC: Interior Trim, Medium Dark Gray
 9UC: Interior Trim, Medium Dark Gray
 A01: Window, deep tinted all, Soft Ray
 A31: Window, electric control
 A90: Deck lid release, remote control, electric
 AAA: A coating on the glass
 AD3: Window, hinged roof (Sunroof)
 AR9: Seat, front bucket, driver, passenger, manual reclining
 BC8: Front door map pocket RH and LH (available only w/A31)
 C41: Heater, with fan and defroster (84-87)
 C49: Defogger, rear window, electric
 CD4: Wiper system, pulse
 D34: Mirror, visor vanity
 D7V: Mirror, inside, RH visor vanity, illuminated
 D80: Extension, rear end panel (spoiler-rear deck lid)
 DG7: Mirror, RH and LH remote control, electric
 E5Z: Mirror, RH and LH remote control, electric
 E9Y: Mirror, RH and LH remote control, electric
 E9Z: Mirror, RH and LH remote control, electric
 FX8: Transaxle, final drive, 3.61 ratio
 K05: Block Heater
 K34: Cruise control, electric
 K99: Generator, 85 ampere
 L44: Engine, 2.8L V6 (Hi Output)
 MG2: Transmission, manual, 5-speed (Muncie) 3.61 ratio
 MM5: Transmission, manual, 5-speed, provisions (85-88 )
 N33: Steering column, tilt type
 N36: Steering wheel, rally 4-spoke (86-87)
 NA5: Emission system, federal requirements
 PH0: Lock kit, aluminum wheel
 TB4: (front) (86-88 )
 TON: (front) (86-88 )
 TR9: Lamp group, courtesy consists of;
 U25: Rear compartment lamp
 U29: Instrument panel, courtesy
 U66: Speaker system, 4, dual front dash mounted, dual extended range, package shelf/quarter
 UA1: Heavy duty battery
 UM6: ETR AM/FM stereo w/clock, cass, auto rev cass,seek & scan (85-88 )
 V73: Luggage carrier, deck lid (84-86)
 VK3: License plate, front mounting package
 W66: Formula option (88 )
 WS6: Performance package, special
 WV9: Package, value leader, (88 ) (2PM37 + WV9 = WPE37)
 X05: Package, value leader, (88 ) (2PM37 + WV9 = WPE37)
 XEM: Package, value leader, (88 ) (2PM37 + WV9 = WPE37)
 YLM: P215/60 R15 BSW STL (REAR) W/P205/60 R15 BSW
 Z31: Build-up, custom door and quarter
 Z49: Export, Canadian modification, mandatory base equipment
| Revenir en haut de page |  |
| Dim Sep 02, 2007 8:09 pm |  Sujet du message: |
| fierodave Pegase d'Or
| Salut bienvenue sur fierotalk gene toi pas pour poser des questions ici on a des specialistes (contrairement a dautre site  )  moi aussi je possede une formula cest un modele rare prend en soin. a tu des photos  de ton projets ca serais cool de voir ca
 White Pontiac Fiero Formula 1988
 http://fierodave.monchar.com/
| Dim Sep 02, 2007 9:23 pm |  Sujet du message: |
| BigBen Pegase d'Or
| beinvenue  sur fireotalk Ben
| Lun Sep 03, 2007 9:28 am |  Sujet du message: Re: Projet: Formula 88 noir V6 manuel au Saguenay |
| superdave Pegase de Plastique
| Lun Sep 03, 2007 10:15 am |  Sujet du message: |
| warko Pegase de Bronze
| bienvenue dans le club falcon_can
 beau projet ,
| Mar Mai 20, 2008 7:22 pm |  Sujet du message: Re: Projet: Formula 88 noir V6 manuel au Saguenay |
|  	  | superdave a écrit: |  	  |  	  | falcon_ca a écrit: |  	  |
 K03: Transaxle, final drive, 3.65 ratio
 C'est quoi la joke, la voiture a deux transmission???
 Sait-tu que je viens tout juste de voir ton commentaire et tu as raison,
 c'est K05 - Block heater et non K03.
 Corrigé !
 merci
	| Voir le sujet précédent Voir le sujet suivant
 | Vous ne pouvez pas poster de nouveaux sujets dans ce forum Vous ne pouvez pas répondre aux sujets dans ce forum
